Ok so I'm in the middle of my rebuild and have the pistons mentioned below. There are a few options for piston rings I'm looking at and seeing how I am rather unknowledgeable in this department, I'm asking you guys. Seeing as my pistons are manufactured from ARIAS, should I stick with their Rings, go Wisesco, CP, or are there others that you guys recommend?
So here are the links to the options I'm thinking
Wiseco
https://www.z1motorsports.com/product_i ... 9n9ir5euv3
CP
https://conceptzperformance.com/Cart/de ... p?II=10981
ARIAS
http://arias-pistons.myshopify.com/prod ... rome-rings
Cylinders: Make: Model: Spec: Head: Head cc:
6 NISSAN VG30DETT TC GAS 4 VALVE 49.5
Displacement: 182.88 2998 INSTALLATION INSTRUCTIONS:
Bore: 3.445 87.50 ARIAS FORGED PISTONS ARE MANUFACTURED TO PROVIDE
Stroke: 3.270 83.06 PISTON TO CYLINDER WALL CLEARANCE AS INDICATED BELOW,
Rod Length: 6.071 154.20 BASED ON BORE DIAMETER GIVEN AT TIME OF ORDER.
Comp. Height: 1.255 31.88 *Clearance: .0040 0.10 MM
Compression: 9.00 9.00
Pin Diameter: .866 22.00
Top Groove: .060 1.5
2nd Groove: .060 1.5
Oil Groove: .158 4.0
Piston Weight: 350.0
Part Number Qty
Pistons: 3520000 6
DISH\4VR-1
Pins: A86623514SN 6
Rings: 1515403445 6
Locks: 866043S 12
Buttons:
*NOTE: IF PISTONS ARE PRO-COATED, SUBTRACT .002 FROM CLEARANCE NUMBER.
GLS:
