thanks..does anyone have an answer to my question about the plate and the rocker arm stoppers tho?positron_ wrote:Excellent!
It looks like you're right. #39 & #48 right? Here is a link to a pinout for your ecu.callmeweezy724 wrote:anyone kno about those two black wires that are loose on my ecu..there both black wires..im guessin there grounds but does it matter which goes to which?
So there should be a link at each dot on the cam gear?duffman1278 wrote:That crank mark is wrong, the gold link needs to be on the bottom, there should be like these silverish links that go at like 10 and 12 I think, something close to that. Give the crank pulley a few more turn, and back at the 2nd to left mark like you have it, and reinsert the CAS.
http://www.kouki.co.uk/referen...nouts
I hope this helps. Lookin good...
yea im goin to try it like that. y would i have to retime it though?duffman1278 wrote:Seems like your links are gone as well. Some people silver links go away after time. It looks good as it is right in your pictures. Although you might have to retime it again when it comes time to start it up. I would try it like that though.
i paid $2100 for mine they didnt charge me tax bc i came with cash. I tried to talk them down on the price but they wouldnt budget. They didnt have an ignitor or shifter for my motor, and i got the transmission harness but only the starter and alternator connections are there the ones for the gears arent there. I called some other spots but they were all out of blacktops and werent gettin any until 3-4 weeks from then. How much u pay for yours??zrowkewl wrote:lookin good man.just about ready to fire my blacktop up.i too delt with engine depot.i had a good experience though.jay helped me out a lot.the guy that showed me the motor (little guy named z) was very helpful as well.he too told me the one i got was the last one and by far the cleanest most complete motor they had. mine came with full blacktop harness with fuse box included. ignitor,maf sensor (they gave me the wrong one though) and shifter was included as well as e5 ecu. can i ask...how much you paid for your motor??
i cut it..no one answered my question so i didnt want to take any chances..we make ac hose and fix powersteering hoses at my job so i took it there and used the cuting wheel and cut it..next time i take my valve cover off ill take pics sry i forgot to do that. Theres some thing i didnt take pics of.Kalypso123 wrote:what about the plate for your RAS
Keep and cut it or trash?
great job
those type of plugs coming from the fuse box?? I have the engine harness all hooked up. the 1st pic is the lower harness that connects to the starter and alternator..and the 2nd pic are plugs coming from the fuse box in the engine bay.. I already have the things you mentioned connectedefrain240sx wrote:youre harness is a little wack man. 1st. Top pic bad angle cant really see the plugs. 2nd pic some look to be male connectors which is weird because all the harness I have worked on, have female connectors , but ill give it a try. brown plug on top I don't know whats that for I never use it, it always has some little cap covering it. Grey plugs, left one looks like the idle valve plug, middle plug looks like the plug for the coil pack harness, right plug looks like the plug for the knock sensor. 3rd pick could be 2 things, if it has a black and brown wires on it it is the power steering plug ( the one on the pressure line ), if it has brown/black and brown wires its going to be the plug for stock boost solenoid. Check does things to see if they are connected
yea im in the same boat..i i had power but my power was working even without at key..im tryin ti figure out y thas happening b4 i even try to start it. I jus tried to bleed my slave cylinder..i forgot to eliminate the dampener box and i was jus goin to leave it but i broke the bleeding screw off in it. so now its def coming out, but thats the lease of my worries i need to figure out y i am gettin constant power.zrowkewl wrote:yea i paid 2100 as well.i tried starting it earlier today,but when i turn the key nothin happened.headlights work,along with all my accessories,but i still gotta connect the slave cylinder,and the DOHC power steering lines.
yea..its sucks bc i didnt take the dampener box out i tried to bleed it so i can bleed the slave cylinder after..and i broke the f-ing bleeding screw off..so now im tryin to take that out but the lines are a bee to get out. you have any pointers or anyone esle?? im ready to jus cut the whole clutch line and run another one. lolpositron_ wrote:Dang man, you're almost there...friggin' sweet!
