Picked up my s13 blacktop today!!
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
ok thanks for the advice i guess now i jus have to get somethin to test and see if im gettin power, i have work tomorrow so ill pick something up..what do i need a multimeter right? i heard i can use a test light too but that wont test for continuity it jus tells if theres power or not is that correct?
I just went and fixed my vaccum lines too thanks for all the help ill keep you updated!
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Yeah a multimeter is what you want they are about $25. No prob with the help, I will always help if i can. I am replaceing my turbo after only 500 miles of it being on the road, but my seals were leaking bad from the beginning, and boost is so fun!
callmeweezy724
word i cant wait! this will be my first time. Ill grab a multimeter from my job n try it out tom. thanks!
callmeweezy724
ok idk if i was doing this right but im tryin to find out what is causing me not to get any spark. I bought a multimeter and tested my ignitor, it was gettin resistance threw and to the other side. so i went up too the coilpack plug and was gettin it there too. Then i tested the plugs that goes to each coil pack and all four were good. Im not sure how to test my coils but i put it to that and i got nothing. Lol im not sure if im doing this right can someone help me out on how to figure out whats not working?
duffman1278
Car: 89 240sx Hatch, the wildcats!
Just ground your spark plugs manually. Do this by pulling out each spark plug invidiually and putting them on the coilpack, then have the spark plug touch anywhere on the block. Have a friend, or someone try to turn it on. You shoud see an obvious spark. Based off of what you have told us on how you tested it, it you still don't see any spark from ALL coilpacks, I would assume its your ECU, or wiring on the ignitor.
If some, or 1 coilpack is getting spark, try swapping out coilpacks with the ones that arn't working. You might just have bad coilpacks.
In the FSM there's a way to test the coilpacks as well with a multimeter, its really SIMPLE, I forgot how you do it though, but iirc you just test for resistance.
I had a no spark issue for a while. Ended up being my wiring lol I was stupid and had some wires touching from the ignitor plugs.
callmeweezy724
check out my other thread zerothread/349742 yea i did that pulled the spark plug put it on the coil pack but i didnt see a spark..
Kalypso
callmeweezy724 wrote:
i cut it..no one answered my question so i didnt want to take any chances...
cool I just got some greddy RAS's also, im going to do the same
Kalypso
i have the same spark problem, with my injectors and spark plugs
the whole shabang is not getting current, but the starter cranks over and I tried two ecu's.
I need to sit down and look at my connections, everything is in, but I might be mistaken.
jiffy08
Car: 92 hatchback 240sx
i think your front right coilover is on the tower wrong... and good luck with the swap!
callmeweezy724
jiffy08 wrote:i think your front right coilover is on the tower wrong... and good luck with the swap!
yea some body told me that in this thread im already on it. thanks tho!
callmeweezy724
Kalypso123 wrote:i have the same spark problem, with my injectors and spark plugs
my prob was my ecu i burnt somethin out i need a new one.. you have one for sale? i need an e5 check out my other thread in this section
Kalypso
what causes ecu's to blow like this
Phyrx
Car: 2001 Audi TT Quattro
Bad wiring, things touching that shouldnlt be, maybe would blow the ECU
Lookin good, but a fair warning, Id get something to hold that hose up away from your exhaust manifold otherwise you'll have a fire on your hands, trust me (the hose from the block to the valve cover that replaces the stock can)
callmeweezy724
Phyrx wrote:Bad wiring, things touching that shouldnlt be, maybe would blow the ECU
aight thanks for the advice!
callmeweezy724
I put my driveshaft back in today..is there suppose to be this much space? i kno yer suppose to use the ka dust collar, but theres a black piece still on my drive shaft for some reason i thought that was it stuck on there...
callmeweezy724
anyone?
MadTechMike
Car: s13 hatch x 2
Hey dude, i just finished my SR swap and had the same question, yeah there is a gap, just the way it is, i was told not to worry about it....
240life
callmeweezy724 wrote:I put my driveshaft back in today..is there suppose to be this much space? i kno yer suppose to use the ka dust collar, but theres a black piece still on my drive shaft for some reason i thought that was it stuck on there...
if you don't have the ka dust collar you can trim 1 inch off of the sr collar with a sawzall to make it work. the gap is normal by the way
callmeweezy724
ok nah i was jus wondering if that space is suppose to be there because i wasnt sure if it was like that or not b4. thanks
callmeweezy724
does anyone have a pic of the grounding points on the sr?
callmeweezy724
ok i dont have my speed sensor hooked up either when i took mine out the sr transmission it looked different from my ka. I thought it was suppose to be the same..what came out of it...and heres wut the other piece looks like on the transmission..my ka speed sensor looks different from that
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
They looked identical when I took them out.
callmeweezy724
yours looks like that?? ill get some pics of mine when i get home im at work right now
