float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Aug 31, 2005 7:44 am
As Avery said, the CA can be hard to get parts for. It's an old motor and most places don't support it anymore. There is some growing support here in the states that seems to offset the diminishing support for it in Japan. If you want a motor that is easy to build and parts can be readily found, the CA is NOT the motor for you. You generally have to have A LOT of patience and time to get this motor built well. Many parts will have to be custom made and will cost more than the comprable SR part.
