Performace Transmitions
naladude911
Car: 2001 Infiniti QX4
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
ask for John...He knows his sh*t....i would and plan to definately invest in this when i get the motor to where i want it...not including the core charge your looking @ $3500 shipped and thats not installed either...if your only doing light mods then all you need for your transmission is to upgrade the valve bodies and any decent transmission shop can do that...if youre planning on doing it big this is definately the way....
naladude911
ya, my transmission i think im not sure, is starting to act up. Im taking it in to the service shop soon to see waht they say. if its like, you need to replace the transmition, im going with this
#1 Sailor Scout
Car: 2007 Honda Civic LX
Infiniti J30 fan
Looks like if you want to put that transmission in the J, then you're going to look @ some major fabrication work. That transmission looks like it was meant for the G35. I'm going to do more research on it, though, just to make sure.
If you have transmission problems, then I suggest getting it rebuilt. The J's have a unique type of transmission, & I don't think that you can just "drop in" an aftermarket one like you can in a Honda or the more tuner-friendly imports.
While we're on the subject on transmissions, is it possible to "bump shift" a J? I was told that it was, but I had a bad experience with bump shifting. I lost a gear. (This was in my ol' Cougar that I had before the Honda.) I can bump shift in my Civic with no problem, but I wonder if the J is the same way.
naladude911
define bump shifting
driverdriver
Car: NICO's longtime resident Canuck!!!
There was someone (some years ago) on this forum who had a level ten transmission in his J. He loved it!
StevieRaySTL
Car: 1990 Infiniti Q45 w/ Nico ECU
1993 Infiniti J30 w/ x-flow
1997 Toyota Landcruiser
-- ....Transmitting..... So are you sending those ssb or ham, maybe via satelite? *snicker*. Don't wanna be too harsh, but seriously, there's two words in the topic and BOTH are spelled wrong. Merriam Webster's can help you in that department. As far as your transmission goes, if it 'aint broke don't fix it, or like sailor said, do a rebuild. Maybe just new fluid. There's nothing wrong with the 4spd overdrive that's in there, nala. Enough said.
yodawill2000
Car: 94 Infiniti J30
Drop the pan and replace the filter.then refill to proper level.
naladude911
can u man shift the J? Cause its got the 1-2-3-D-R-P gear selector
yodawill2000
uh yeah if you leave it in first it will stay there .. 2nd .. ect.
naladude911
it will? So like if i put it in (1), put on some gas, the RPM wouldnt increase and tell me to shift to (2), then (3)? Lets say I was in (3), can I downshift to (2)
yodawill2000
the J wont talk to yo budPut it in first and it will run till you blow up.
You gotta lot to learn Mi' amigo
gr8scott72
Car: 1994 Infiniti J30t
yodawill2000 wrote:Put it in first and it will run till you blow up.
Actually, it will just bounce off the rev limiter. Of course, it might eventually blow up. lol
Jakw
Car: 1993 J30
I have to laugh at posting this on a forum as opposed to going out to your car and trying it. So...ha.
StevieRaySTL
yodawill2000 wrote:the J wont talk to yo bud
-- LMAO, this thread is excellent. Vrrrroooommm is all my J has to say, apparently.
driverdriver
In D1, transmission will shift between L and D1.In D2, transmission will shift between L, D1 and D2.In D3, transmission will go up to D3.In D or Drive, all the gears are available, including overdrive.
Most of the time, D is just right. Its also the most fuel efficient gearing to be in.If you're towing a trailer, you probably want to keep it in D3.If you're driving in icy conditions, you might want to keep it in D2, maybe D1.If your having a hard time going up a hill, you may want to put yourself in D1 or D2.
#1 Sailor Scout
Infiniti J30 fan
^ What he said. Bump shifting defined. But will it help the J's performance or hurt it?
kbflip02
2006 Infiniti G35x
#1 Sailor Scout wrote:^ What he said. Bump shifting defined. But will it help the J's performance or hurt it?
as far as i know bump shifting in the j30 for racing purposes will be more wear and tear in the transmission and decrease its life
gr8scott72
kbflip02 wrote:as far as i know bump shifting in the j30 for racing purposes will be more wear and tear in the transmission and decrease its life
It's pointless. If you're racing then you'll be at WOT anyways and if so, the transmission will hold the shift point to max anyways so you wouldn't be gaining anything by doing it manually.
If you're not at WOT then manually shifting it might be of some benefit so to hold it in a gear longer than the transmission would want to on its own but I find the J30 transmission is kind of slow to shift anyways.
naladude911
What is WOT?
yodawill2000
Wide Open Throttle.
Pedal on the floor.There's a switch that closes when you floor it and that tells the ECU you wanna go NOW !!!get in the car but dont start it.press the gas pedal slowly to the floor and you will hear the switch click when you get to the floor.
#1 Sailor Scout
Infiniti J30 fan
yodawill2000 wrote:Wide Open Throttle.
& make sure that you don't have your stereo on; otherwise, you won't hear it.
