YOU ROCK!! 20 bucks and simple, no welding. I guess I will save the welding for later....AZhitman wrote:steed - Here you go:
http://www.nicoclub.com/articl...shtml
The shim kit looks like this:
http://www.rockauto.com/catalo...DE%5D
Both would need to be used by an alignment shop, so usually allowing them to install them would work.viet510racer wrote:so these are ideal to a lowered car. which i assume that it is good for daily driving to have theses installed, and probably improve handling even more? how about the camber bolt kit that versaspeed has? are both easy to install?? can anyone do a write up on both??
Should get the shims for the rear alignment to be perfect.nick425 wrote:Mmk im new to all this. If I buy the Tanabe NF210, I should also buy rear shims? What about the front suspension? No shims for that? Thanks!
Then you didn't get a rear alignment.VersaMG08 wrote:I had a re-alignment done after I got my Tanabe springs installed, but I don't have the shims. Next time I get another alignment, I'll have to get the them installed.
