cbcrippler »
https://forums.nicoclub.com/cbcrippler-u15350.html
Sat Jun 19, 2004 1:32 pm
you are absolutely right, I realize it's not a filter, but a valve, I mis-spoke, since i've been working on all my filters. thanks for being patient with this beginner, i'm slowly but surely learning and working on 1 thing at a time. air filter/cabin air filter/fuel filter, and pcv valve WAS next on the list (easiest on up...)IF i were to decide to replace it, it looks like there are factory type clamps on the tube, would i have to get replacement screw type clamps after removing them, or are the clamps that i see as factory clamps spring loaded or once i pry them off can they be reused? i just didn't want to pop them off without knowing the consequences. I put some light pressue on them and felt that it wasn't going to come off easy. I've also read you should soak that area a litte before really attempting to do so.
