Should be interesting. 1-3 loos alot closer.jdmser wrote:Exactly, the cool part is that the 2wd v6 pathfinder were produced from 1986-2002 so there are abundant used transmission out there for anyone who has a rb25 or 26 bell housing.
so the flange is the same on the rb25 and rb26 bell housing where it mates with the transmission casing.jdmser wrote:Exactly, the cool part is that the 2wd v6 pathfinder were produced from 1986-2002 so there are abundant used transmission out there for anyone who has a rb25 or 26 bell housing.
But I wanna peel out! lolWhatsADSM wrote:Good info.. Always nice to have another option! Once you are done take a quick pic of the shifter mounting. Also is the tail the same total length as an RB trans, or will you need a new driveshaft?
My only other comment is that, I'm actually not a fan of the gearing at all. IMO WAY to short in first gear. There is a reason most big horsepower stuff has a long first gear.
I have a guy considering doing a RB Frontier. We'll seeGTRs13 wrote:Hmmm. RB Pathfinder...
You can do a 2jz in a 4Runner, so I guess this will be the next big thing!
I don't have a rb25 transmission to compare the two so I can't answer that. Once the transmission is in I'll be able to take measurement to see what kind of drive shaft will work. As for the gearing, it's for my rb24. I'm basically compensating for a lack of torque with gears. I when I get to a point where I have torque in goes the q45 diff.WhatsADSM wrote:Good info.. Always nice to have another option! Once you are done take a quick pic of the shifter mounting. Also is the tail the same total length as an RB trans, or will you need a new driveshaft?
check out the nissan Patrol...nearly the same thing as a pathfinder and yes they Rock RB's in them overseas...GTRs13 wrote:Hmmm. RB Pathfinder...
yes providing you have the required tools to disassemble it properly and reassemble properly same size shafts and all..you will also have to change out the counter gear too id imagine cause that should also be differentDarius wrote:Would it be possible to switch out the 1st and 2nd gears from the 300ZX transmission to the pathfinder transmission?
1st and 2nd gear are already worthless on the RB25 with street tires.
Don't they rock some 4L straight 6 goodness as wellS14-NEO wrote:check out the nissan Patrol...nearly the same thing as a pathfinder and yes they Rock RB's in them overseas...
