Pathfinder SE 99
core
sorry to bother guys.. have one more question.. just bought the 99 pathfinder SE with 85k miles.. trying to find out what maintenance might be due on the car... so far i've changed the engine oil/filter.. thanks in advance..
flavluvsnismo
Car: Cars, long walks on the beach and sunsets
If you bought it from a dealership, then they probably took care of the 90k tune up. If not, then you should take it to get the 90k tune up.
NISTECH
the dealer will not likely do the 90k..they smog and saftey used cars as cheap as possible to increase their profit on the vehicle. reccommended service at 90k is as follows:oil changeoil filter changeair filter changefuel filter changetire rotationbrake inspectionwheel bearing packcoolant drain and refillbelt inspectionsuspension inspection(to include all bushings)alignment inspection(evaluate tire wear on tires with 5000 plus miles on them)trans fluid flush(90% plus complete flush with machine)Battery terminal service and fluid level check with CCA test
that pretty much covers the 90k stuffnow at 105k you will be due for a T-belt replacement and changing the NGK platinum plugs(strongly recommend using NGK's as the replacement) other brands fall short in quality and reliability in nissans.
