Isn't the chassis connected to ground? So, wouldn't connecting it to the chassis be the same thing as connecting to ground?moso wrote:240sx window motors dont ground through the body, they are direct wire. hit one lead up with hot and the other with ground and it will roll up/down, reverse polarity to do the opposite. if the motor wont function like that than it is bad.
mike9ellis wrote:Isn't the chassis connected to ground? So, wouldn't connecting it to the chassis be the same thing as connecting to ground?moso wrote:240sx window motors dont ground through the body, they are direct wire. hit one lead up with hot and the other with ground and it will roll up/down, reverse polarity to do the opposite. if the motor wont function like that than it is bad.
Do these motors have speed controllers like an RC car? If so, a speed controller could be fried. However, I can't imagine why they would have those. I would just connect the 12V and GND right to the motors themselves. The speed is really on or off.moso wrote:you got the right idea, the switching system is a little more complex than a simple 3position switch but it serves the same function. if your giving your motor direct current and it wont function, switch polarity, still nothing....throw it away.
I image a break in any wire would cause it not to work. Can you probe what the voltages are on those wires when you press the window button?Promise Land wrote:If I have power from the white/black wire (power in) to the motor, would a break in the red/white and red/black cause the motor to not work? These are the wires coming from the driver's switch assy.
BAHAHAH. True. My girlfriend was freaking out her vert's window wouldn't roll up. I pull up, push the switch, and walk away. WOWOWOWbiggie wrote:To state the obvious, did you make sure the window lock isn't on?
Ha ha. I love those fixes. You are a God, lol. Just don't make her feel too dumb. Girls are sensitive about that kinda stuff. I'm speaking from experience.allenms240 wrote:BAHAHAH. True. My girlfriend was freaking out her vert's window wouldn't roll up. I pull up, push the switch, and walk away. WOWOWOWbiggie wrote:To state the obvious, did you make sure the window lock isn't on?
