Partial Rebuild
dreamsOfSkylines
My timing chain recently ate through the upper guide, allowing it to bounce around inside the front cover. I've decided to go ahead an pull the whole engine and give it a bit of a rebuild (the odo is broken but I'm guessing 100k - 120k). So far I plan on replacing: timing chain and sprockets, PCV, all belts/hoses, valve seals, water pump, 02 sensor, and oil pump. I would also clean the deck adjust valve lash etc. Any one have suggestions for other stuff to replace? I'm thinking maybe main bearings, piston rings (with honed cylnders of course). Any suggestions, tips, etc would be greatly appreciated.
Altiman94
Car: 1989 Nissan 240SX
if your engine is torn apart, you might as well go ahead and do a full rebuild. That way you have a fresh engine with 0 miles on it.
dreamsOfSkylines
How much would it cost for all the micrometers needed? My plan was more or less to replace any wear items. If I get new piston rings and get the block honed that would fix any taper right? Other than that I could just do the main/rod bearings, all gaskets/seals, core plugs, thermostat, and what I listed above. Valve guides I can check without measurement just by wiggling valve inside, bent valves should be easy enough to find without measuring tool. Should I go ahead and replace the entire timing chain assembly (tensioners and all) or do you think that just the chain and sprockets is ok? Any Ideas for cleaning all the gunk and carbon that has undoubtedly built up over the years? Seafoam maybe? How about the fuel pressure regulator and injectors? I know my way around an engine but this would be my first full rebuild so any advice would be great.
s13ofdoom
Car: car, music, sports
do a swap! and if u want to do it ur self i recommend taking an engine class at ur local community college. u'll learn alot!! and some ones always there to help!!
dreamsOfSkylines
I'm, in a class right now where we build engines, but alot are american pushrod style, with one OHC ford V-6. I feel confident I can do it, i just want advice on the most important stuff to do. I don't have cash for swap right now, when I do though...
s13ofdoom
ya i have the same experience as u then but id be happy to help ! :)
