I'm trying to identify the hose in the following photos so that i may place an order for the exact part. Note the green arrow. It is the same part but from different angles / zoom. I suspect there is a crack in the hose but before i can do anything with it i need to identify what the entire line is and the hose name. The line is coming from behind the intake manifold and ends at some part below the throttle body.
The bigger problem is there's a leak occurring in the area. It looks like coolant but i could be wrong. I will get an endoscope USB cam to try to identify where the leak is coming from but from the wetness around this hose and the fact another line behind/below it was also wet makes me believe this indicated rubber hose is the issue. ODDLY ENOUGH, when the leaking starts it keeps dripping but as soon as the radiator fans turn on the leaking stops. When the radiator fans turn off perhaps 60 secs later the dripping begins again.
Would appreciate you chiming in.
Thanks
