rover3l »
https://forums.nicoclub.com/rover3l-u10518.html
Sat Dec 06, 2003 7:18 am
Thank you very much for the advice. Since last weekend when I changed the strut accumulators the ambient temperature up here in the Buffalo area has dropped from about 50F to 25F so I hope this is part of the issue.
One strange thing was when I was changing the accumulators after bleeding out the fluid at the rear of the car, no fluid bled out of the strut top bleed nipples. There was clearly no pressure there.
The active fluid level so far is still at the high mark on the dip stick so it is obviously not leaking badly.
Dumb question but is fluid in the strut itself the active fluid or is it separately assembled and has its own fluid, hence the yellow / brown color?
