VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Sep 26, 2021 8:34 am
There's a bit-bang "diagnosis line" between the ECM and TCM on most of the pre- and early-OBD Nissans, and P1605 is basically the ECM saying, "Hey, looks like the TCM is dead." Which of course it is if the TCM fuse is blown.
The two most likely causes of a TCM fuse blowing repeatedly are degraded wiring inside the transmission or a solenoid with degrading coil insulation. The former can usually be repaired DIY if you can locate the problem, but that generally requires dropping the Valve Body. The latter can generally be identified with an ohmmeter, just look for a solenoid with substantially less coil resistance (DCR) than the others. Individual solenoids for early models are generally available as repair parts, at least from the aftermarket if not OE.
