NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue May 17, 2005 5:30 pm
Your books are correct our article is incorrect, both codes are for the right bank. Lets get this clear,
You have replaced both the timing sensor and the solonoid for that bank? Your light when you try to clear it it just comes right back on when you start the car without driving it?
If you anwser yes to both questions there is one other incedent I have seen but only once and it was due to a tech improperly testing the circuit, he shoved a paper clip into the timing sensor connector expanding the terminal in the connector so it didnt make good contact with the terminal in the sensor. So pull the connecotr off and look in the terminals of the connector, do any of the whole look round or expanded at all? Also look for any moisture in the terminal area of the sensor [have seen that cause problems on the crank and cam sensors on the sentra,same kind of sensor]
