P0420 OBD Code
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
msymms
Car: 2011 Versa
Hi All,
My 2011 Versa is throwing the P0420 Code. I have done some research and I realize that this may be O2 sensor related. So, has anyone had this issue and resolved it? Should I try the O2 sensors first before the Cat? Can this be DIY? I want to avoid the trial and error system of car repair. I did that enough in high school. :crazy:
TIA
-mark
jasonkg
Car: 1991 240sx
Bringing this one back from the dead in hopes of helping someone else in the future. Wish I would have saw this post sooner...
I had the same code and performed a series of trial by error repairs... I replaced both O2 sensors first, that did not fix the problem. Then I bit the bullet and replaced the Cat which ultimately fix the issue. Since O2 sensors are replacement parts I didn't mind replacing them since their bound to go out eventually. I had about 90000 miles on my car when this occurred about 1.5 yrs ago. Hope this helps anyone else that gets this code in the future.
Return to “Versa Technical Discussions”
