brushandcr wrote:I had thought the warranty was 8 years OR 80K miles and since I was at 74K miles it would be covered. If not, this likely isn't a good situation unless it turns out to be the reprogramming.
The start up was semi-rough for a month or so (it wasn't bad and went away after 20 seconds) and finally came up with a code that showed LEAN on both banks. I brought the car in and the local shop cleaned the throttle body and did not resolve so the next day they replaced the MAF. That night when I picked it up it was much better - no roughness at all and had no issues for ~2 months until the light came on. I got the code and cleared it to make sure it wasn't a fluke and a couple of days later came back on.
Q's:
In regards to the reprogramming, the local shop did do this (and was charged as such - $60); are you all saying this reprogramming is not the same or worthless compared to what the dealer would do?
The warranty is definitely over if at 74K miles (10 years old)?
I can do some basic work on the car, but wont be able to do any of the O2 sensors, pre-cat, etc. What is the general cost for the pre-cat replacement, 02 replacement for parts/man hours?
With the car the way it currently is, am I doing more and more damage each trip to work and should have this examined asap? I will try and schedule the reprogramming as soon as I can, but if that is performed and it does not fix the problem, am I killing the car by continuing the drive 50 miles a day on it?
Thanks.
Some bullet points:
*Yes the warranty is 8 years or 80k miles. (Whatever happens first)
*You will prolly have to replace part of the catalyst. Dealership cost is going to be very high. One cat is prolly 1000.
*Now in the second paragraph be more detailed. Did that same lean code come back or did another code come up?
*The programming i cant imaging would be much different or different at all then what the dealership uses.
*Yes if the original delivery date of the car was before 1/4/03 its out of federal emissions warranty.
*Well depends on which cat you have to replace. Shops might charge anywhere from 1 hour to 4 hours of labor at anywhere from 80-150 dollars an hour. As for parts as i stated above one factory cat could go for 1000 if you buy at a dealership plus labor. I've used aftermarket cats and have never had a problem. As for the 02 sensors, an example, one guy asked for 2 hours with diag just for one 02 sensor, the part was 300. I got lucky since i work at a shop i got it in for one hour and bought an ngk plug from amazon.com for 70. (Thanks loystock) If you get some quotes look at how much time(labor) they're asking for and how much the part is. Also ask them where they get their times from, that dude wanted to charge two hours but the labor book only calls for one and IMO 1 hour for diag is too steep for me for a damn 02 sensor.
*I wouldnt worry about a bad catalyst. Just the 02 sensors are sayingto the computer its not doing its job of converting the exhaust gasses into less harmful materials so you have a cel (check engine light). Hope this helps....
