i have headers (that came with y-pipe) and i passed. the hydrocarbons went from 9 to 86. thats not really relavent to you being that you have OBDII. as long as your CEL is fixed, you're fine. on the 'catalyst efficiency below threshold' code, most people that get that code replace the rear o2 sensor (behind the cat) or the cat itself. the only reason i have any knowledge of this is because i work for advance auto parts. the customers that do as i have stated says it fixed the problem, no more CEL. the actron diagnostic tool that we (AAP) and auto zone use is vague to say the least. about the only way to be sure whether or not it is the o2 or cat is to have a diagnostic test done at the stealership or a shop ($50 - $65). that's just to be safe. my recommendation would be the rear o2 located in the back side of the cat. good luck with it bro.asianstyle wrote:. . . if I buy a aftermarket y-pipe for my 01 max, will it pass emissions since it will get rid of the pre-cat on my ride. . .
Aluminized... Not making the under carriage show quality, so I saved the $$$ and bought the high flow cat too.asianstyle wrote:hey beancooker, do you have the stainless steel or aluminized?
