loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Oct 20, 2010 11:43 pm
Again, we have to know if you have Federal or CA Emission configuration. To find out, pop the hood and on the underside of the hood, you will find a white sticker - CATALYST: If it states that it complies with CA Emission, then you have 4 O2 sensors. Otherwise, only 3 sensors.
Federal configuration has 2 front O2 sensors (on the exhaust pipe below engine) and 1 rear O2 sensor (mounted downstream of the main catalytic converter). The CA configuration has 2 front sensors and 2 rear sensors mounted on the Pre-Cats (2 ea). There is no O2 sensor in the main 'cat.'
The Bosch OEM O2 sensors are rated at 100K miles but it does not necessarily mean that they will fail at that mileage. Most of them last beyond 100K miles, especially if the car is maintained properly and has used Tier 1 fuel. An O2 sensor may fail prematurely in case of contamination (oil, etc) or driving the car for extended period with 'rich' fuel-air mixture. I replace O2 sensor 'as failed.'
It will cost you a lot to have it fixed at the dealership. Even though you already have the trouble codes, they will insist on running their own diagnostic which will cost you @ $60. But then, they usually give up to a year warranty on the repair. You can save a lot of money if you buy the parts yourself (we can direct you where to buy them) and have them replaced by a trusted mechanic. You have to ask relatives/friends for a reliable shop that handles Nissan cars.
Again, the KS can be replaced without removing the intake plenum. It will cost you more if they insist on removing the plenum to replace the KS (more labor charges and gaskets have to be replaced.
