Postby VStar650CL » Thu Jan 13, 2022 7:48 pm
P0113 is for excessively high voltage, not excessively high temperature. The IAT is a negative-going (NTC) circuit, so the voltage rises as the temperature falls. Since the circuit is pulled up by the ECM and pulled down by the sensor, it will go to full voltage and read "Siberia" when disconnected (usually -44F).
