robomatic12 »
https://forums.nicoclub.com/robomatic12-u138186.html
Tue May 11, 2010 6:30 pm
Did you check the IACV? Clean it out. Clean every connector under the hood for corrosion and fill back up with electrical grease. Do you have an aftermarket air intake (popcharger)? Also check for vacuum leaks: broken vacuum lines, manifold leaks. We need more info.
