Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Mon Sep 08, 2003 2:15 am
The good news... i had the same exact problem, i traced it to the T-stat (ran the engine without one in), changed it and no luck. The radiator would pulse fluid up and down like there was flow, but the top hose was always hot, and the bottom hose cold (no flow). I replaced the T-stat again, no luck. So i took it out and replaced it with a restrictor plate. It worked. By the way, i used cheap aftermarket T-stats, don't you buy anything but nissan...
But If taking it out does not work, your problem is probably the head gasket. The space on your head gasket between your coolant holes and something else in your head is leaking. Smell the coolant tank under the hood to se if it smells like gas or oil. If not, have a local shop test the coolant tank under your hood for hydrocarbons. Not cheap, but hope it helps.
