Gramentz »
https://forums.nicoclub.com/gramentz-u40915.html
Mon Feb 05, 2007 2:35 pm
I've searched on multiple forums about this issue I'm having. I will try to make this as condensed and specific as possible. I had an SR, sold it, purchased a KA and swapped it back into s14 chassis.
Brand new radiator, rad. cap, and thermostat from advance. I am using the stock clutch fan with shroud. Heater hoses: left-top firewall, right- lower firewall.
Starting the car, the temp takes a while to reach normal operating temp. A short while later, anywhere from a minute to ten, it will start to overheat. Sometimes it will not overheat at idle whatsoever; only when I go for a drive.
At idle under normal operating temp, the heater does not blow hot/warm air; only cool. (I do not have the heater control valve, so it only blows on full.) If it overheats while I'm driving, it will then blow hot/ warm air. It seems to be hit and miss as to when it blows hot air.
The lower radiator hose does not get warm or hot. It feels completely cool at all times. This is why I replaced the thermostat originally, but it did not change the temp of the hose. I bled the system by first removing the radiator cap while the engine was warming up to top off the coolant level. Once the coolant was topped off, I unscrewed the 10mm bleeder while the heater was on full blast (even though it was blowing cold air). I had it loosened for a good 5-10 minutes to let out the air but it still started to overheat it seemed. Every now and then coolant would spit out of the bleeder valve or fizzle out, but no steady surge of coolant.
I am also throwing a few codes: EGR solenoid, Crank Position Sensor, Knock Sensor, and IACV. These shouldn't pertain to my heating issue, right? Only every now and then it will throw the Coolant Temp Sensor code and this is the one I question.
I know the stock temp gauge is not that accurate, but when it climbs and I turn it off, and then back to ACC a few seconds later, the temp reading is different than before. (I.E., between middle and H line, then to normal temp.)
Compression test seemed to yield normal results and two adjacent cylinders did not read abnormally low, leading me to believe this is not a HG issue. Although, when I did remove the spark plugs, cylinders number 3 and 4's spark plugs looked almost as if they were spray painted black and looks rusted/corroded where it seals. These are brand new spark plugs.
I am not sure as to the condition of this engine and its history because it isn't the original. It does sound okay/decent when it is idling though.
Here are my questions: Is the coolant temp sensor code being thrown because the car is overheating? Or is the car overheating because of a faulty/bad coolant temp sensor? The radiator from advance has two extra nipples on the bottom (assuming its for a trans cooler on A/T?), these came capped and I just left it capped and untouched from the box. Do these need any modifications or is this relating to my heating problem? Even if it overheats, the lower radiator hose should still get warm right? Granted, I can take out the thermostat completely to test this, but if there's any other suggestions, I'd like to start there.
Thanks! Really do appreciate it!
