I`m not a mechanic but you seem to be saying you removed the stat and you are no longer overheating. Sounds like air or your new stat didnt have a jiggle valve.Frankz28 wrote:Flow test on the radiator - OKChanged the water pump and the thermostatStill overheating.Removed the thermostat.Doesn't overheat.This winter the temp gauge barely moved.Fan clutch spins about 3 times when pushed manually and doesn't feel sloppy.So what should I do now?ThanksFrankz28
thanks for reporting back on outcome. these thread are pretty useless if people dont get back with what happened.Frankz28 wrote:Over HeatingI changed the thermostat, which I bought from Nissan (w/jiggle valve), and also replaced the fan clutch. So far so good. The car is not overheating.Thanks for all your input.Frankz28
