Overheating HELP!!!
s13drift_89
Car: 92 240sx
i have a problem w my car overheating. it started when i saw some coolant smoke coming out from underneath the hood. i did a visual inspection and saw that the radiator was cracked. i tried to do a quick fix by using some of that radiator patch but that only lasted like3 days so i replaced the radiator. ever since then the cars has been overheating irratically and the heater isnt as hot as before. people had told me to flush the radiator again so i did but it still overheats sometimes. is it possible that while the radiator was cracked lack to the head caused it to warp??I did change the thermostat to. when i drive it for a while the heat works and gauge goes back to the middle/
a little help??
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
If the heat is going up and down you might have air in the system. That would do it. Also try replacing the radiator cap. Just a couple simple solutions.
MYDIME
Car: 71' 510 KA24DE for now, 07' E350
I agree, it sounds like it has air in the system. Try (starting from cold) start the car without the radiator cap on and the heater on full blast. Play with the throttle a little bit and watch the coolant level. Correct it as needed. The air should be out of the system when you have hot air coming out of the heater at idle.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
make sure you remove the that bolt next to the top hose, forgot what its called, and jack the front of the car up and go make yourself a peanut butter and jelly sandwich because you gotta let run for a while. I did mine for a half an hour
s13drift_89
Car: 92 240sx
Yeah i let it run without the cap for about 30-45 min but it was taking tolonmg the air did get warmer though i didnt jack up the car or take that bolt on ima try it again thanx
DALAZ_68
Car: 90' 240sx CA18det
-RJ- wrote:make sure you remove the that bolt next to the top hose, forgot what its called, and jack the front of the car up and go make yourself a peanut butter and jelly sandwich because you gotta let run for a while. I did mine for a half an hour
bleeder
heres what u do
jack up the fron tof the car or park it at an angle so the front is higher...
fill radiator to top
unscrew the bleader screw (as described being right were the top rad hose connects)
turn car on (leave cap off)
let car warm up
start adding water
keep adding until all air stops coming out of the bleeder valve...
when water / coolant starts coming out close the screw and
top off radiator wiht w/e fluid ur using.... and ba, uve properly filed ur system
