Overdrive
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
bladesbravo
Car: Nissan Versa '08 SL
So if CVT is a transmission that is always at the most efficient gear why have overdrive?
Am i missing something here?
alonsorules8
Car: 2008 Nissan Versa SL HB
With the overdrive button in the off position you can utilize the engine brake and slow the vehicle down without using the brakes. Also with the overdrive in the on position you get lower rpms than if it was left out.
Andrews Chalmers
Car: Versa '07 SL CVT
alonsorules8 wrote:With the overdrive button in the off position you can utilize the engine brake and slow the vehicle down without using the brakes.
Engine braking occurs even with OD off... I believe the OD button is intended for those super steep hills..
Return to “Versa Technical Discussions”
