PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Wed Oct 08, 2003 1:59 pm
Ok, here's what has happened since my last post.
I checked the wastegate with a pump.. it starts to show movement at about 5 psi and by 7 it is all the way open and has hit it's mechanical stop. So that should not be a problem.
I redid the vacuum tree that connects my boost gauge, bypass valve, and whatever else it runs off into (It goes underneith the intake runners) so that all the connections are very tight. So that should no longer be a problem.
I took off the bypass valve (bosch) and inspected it.. no tears, to clogs, looks good. Reinstalled it. Should not be a problem*
So I took it out for a test run. Waited till 3rd and a clear road to try anything. The wastegate is working now without a doubt. I gave it some gas and the boost hung around 5-6. So I kept testing. Gave it some more gas and let it go up the gear.. once it gets past like 4500 the boost gets higher. I let it top out in 2nd.. 11 psi was the max.
Now I was planning on running 10psi anyway so I wasn't worried about hitting it.. but I should not be hitting it with this wastegate. I am calling the shop I bought my turbo from to make sure this is definately a 7 psi internal wastegate. But if it is, what could the problem be? Even though I plan on running this amount of boost, I don't like the fact that I am not in control.
* I am thinking that the bosch, which is probably the lowest grade bypass/bov, it not capable of keeping up with the amount of air I am flowing. After all it is just a simple rubber and plastic valve.
