Yes things that dont need to be monitored in a stock 350z.R350Zz33 wrote:yes it is way rice monitoring the systems in my car YOU are so right.
Again, nothing that needs the gauges that you mentioned...RICESecret intake probably means secret ebay pipe with popcharger filter, and custom ebay fairlady z emblem...R350Zz33 wrote:he hooked it up to the vacuum line right but mine is gonna be for vacuum not boost my z wont be stock much longer.i have put some money aside and as soon as i open a new bank accont and get a debt card parts will be rollin in n20, hks high power, my secret intake, line lock, a new custom black 350z logo ect
Might I recommend to also get the gauge which monitors the exhaust bearing.R350Zz33 wrote:yes it is way rice monitoring the systems in my car YOU are so right.
..sure.(?)xjmxstac wrote:You mean the EBM gauge?
soup that is a funny site man i bet richie got all excited when he sawthe tampon dispenser for automatics. that was one of my favorites hes always posting crap saying hay look at me i wanna get flammedDasoupdude wrote:
..sure.(?)
And richie if you plan on running the track you need an O-pipe, cross drilled brake lines and a new heavy duty clutch belt.
http://kalecoauto.com/index.ph..._id=2
http://kalecoauto.com/index.ph...id=13
http://kalecoauto.com/index.ph..._id=1
Prices aren't that bad if you ask me, I'd get the cross drilled brake lines if I were you before the line lock.
oh yeah and a oil bypass kit if you really don't feel like getting your oil drity running through your block, its good especially if you have the HR motor.
http://kalecoauto.com/index.ph..._id=8
Dasoupdude wrote:
..sure.(?)
Perhpas I sound naive but is there really such thing as a 50 shot of direct port..?R350Zz33 wrote:nos 50 shot direct port
You're gonna put NOS on a track car?...Now that's F&F!R350Zz33 wrote:no vacuum forgot about nos 50 shot direct port should be ok right? i was just lookin to fill the third hole?(i know what u are thinkin (perverts)) i wanna track my car im gonna call the local circle track we have its all we have .
R350Zz33 wrote:well i was gonna do a 50 shot
R350Zz33 wrote:swap out the jets
R350Zz33 wrote: i wanna take it to a track for a few laps
You're gonna use Nitrous in a oval track? Are you stupid?R350Zz33 wrote:well i was gonna do a 50 shot to be safe untill i build it then i can just swap out the jets i dont wanna blow the motor and im not gonna run it on the track really i wanna take it to a track for a few laps so i can legally open it up
