yeah those are nice but i'm not really trying to spend $4K on a set of wheels and tires, I'd rather put that towards performance mods if you know what i mean. I know it's a 3 pc wheel versus the 1 pc R-1's, but that superleggera is the same weight as the R-1 Drift, 3 lbs heavier than the Victory, and 5 times more expensive than either of the other two. I've looked high and low for other wheels that I like as much as these two and I kind of have my mind set on getting one of the bunch, just trying to narrow it down to which one. Thanks for your suggestion though.nismo2K2 wrote:you should check out the O.Z. Superleggera rims, those would also look nice on your spec v.
What's the price difference?jbarbaresi wrote:the only thing that turns me off about the victory (second wheel) is that they have both 5 X 100 and 5 X 114.3 bolt patterns on the same wheel. i know that's fairly common with 1 pc wheels but i need the 5 X 114.3 bp, and if you look in the picture that is the outside holes on this wheel. i think they should have reversed it to make the primary bolt pattern 5 X 114.3 since that is the more common of the two. the outside holes don't seem to be as sturdy.
the victory's are only about $100 less for the set of 4, not enough to really sway me one way or the other. the reason i'm leaning towards the victory is because it's only 7.5" wide as opposed to 8" in the Drift so i will have a little more room to play with if i need to put in a small spacer in there for more brake clearance. its also 3 to 4 lbs lighter. i've seen the drift in person and it is a sick looking wheel, i wish i could see the victory before making a decision.nissantech06 wrote:
Can't say I'm a huge fan of spacers, they change the whole stance of the car.jbarbaresi wrote:
when i say spacer i'm talking about a little 5mm spacer, just enough to give a little more brake clearance but still not even enough to really notice. i agree that i dont like the look when people put large spacers on there.nissantech06 wrote:
