Operation VH45DE 5 Speed adapter plate IN PROGRESS!
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
im pretty sure the thread and pitch are common, if memory serves theyre just M10s.. Fastenal or McMaster-carr should be able to hook me up.
tmorgan4
Car: 2000 Nissan Pathfinder
M10x1.0. I looked all over for mine including McMaster-Carr and everyone carries M10x1.0 but only in an 8.8. I'd be wary of using those as flywheel bolts!
Carl H
check out the rb or z32 flywheel bolts...they're freeking huge!
Mountnman
Car: Nissan maverick/patrol 1996GQ Dual Cab Chassis [modified lengthened with Tray back]
Hi
I'm new to this game
Baz R is my name Mountnman is my pseudo name
In the middle of installing a TT VH45de with dedicated LPG sequential vapour injection in the modified body. Gearbox issues are my issue
I am curious about the make of the gearbox picture in your post.Is it a Fs5r30a 4x4 ?
thejapino
Car: '93 J30t
So... anybody who picked up the plates from the first test run do the install and r&d'ing yet? Im very curious to know about the progress.
5spd G50, mmmmm, cant wait. drooling
Raxephon
Car: '04 RX8...for the moment...
Anything new?
I have cash in hand whenever these are ready.
minh300zx
Car: 1990 nissan 300zx NA 2+0
Hi Wes
how much are the adapters?
ZX2NV
Car: Nissan 300zx 1995 2+2 TT
We seem to be getting really close to getting these done and dusted. Wes can update the thread as it happens on his end.
The wait is almost over
TBrack
Car: none
driftnomad
thejapino wrote:I'm gonna try and make a Z32 setup fit!
That's what i was going to try to do. I am in the middle of buying parts for it right now. I figure that if you get everything form a Z32 TT that if you use the pedals, master and slave cylinders as long as the hardline running between them is the same lenght and diameter, you can bend your own to make it to fit. I was thinking about converting to the Z32 TT E-Brake setup, but I want the setup out out of a larger car maybie R-32 (4-door if possible), or something because reguardless of everything I don't want the integrated drum setup for the e-brake.
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
The Z32 and the R32/33/34 all have a drum/disc integrated handbrake. The GTR and Z32 setup is nearly identical and most parts are interchangable...
elwesso
2007 BMW M Coupe
Heres the plate!
SuperHatch
Car: 96 TLC
So whats the price Wes?
elwesso
2007 BMW M Coupe
$350 + Shipping, which shouldnt be much since this part is thin and not heavy at all...
thejapino
Car: '93 J30t
Are they for sale now? How many do you have?
SuperHatch
Car: 96 TLC
elwesso wrote:$350 + Shipping, which shouldnt be much since this part is thin and not heavy at all...
Does this include the required flywheel spacer and hardware? (flywheel bolts, adaptor to engine, trans to adaptor bolts)
If so... I'm sold.
elwesso
2007 BMW M Coupe
I dont provide a spacer with this because its only 1/4 inch, I was thinking you could take 2 of the VH45 flexplate spacers and just use that, theyre about 1/4 thick anyway. I really dont think that you would even need to use a spacer, in which case you could use the stock VG bolts.
I have to source the other bolts and im going to have someone test fit the plate before I sell them to the general public, but yeah, it will include everything.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
How long will it take you to source the bolts. I was getting ready to ship my trans to Mazworks but if yours will be ready soon I would rather not have to machine the trans.
I have engine and trans in my garage if you need someone to test fit it.
Put me on the list for one when they are ready. Paypal ready and waiting
elwesso
2007 BMW M Coupe
Theyre just standard countersunk bolts, 3/8 is going to be the right size, so theyre ultra easy to find!
Im guessing fastenal or mcmaster-carr should have them easy. All they need to be is long enough to go from the plate to the trans and have room on the end to put nuts on.
The ones that are custom made are already in my hands!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Heres the plate!
Ouch! That's a little rough! Did the template shift when you drilled?
elwesso
2007 BMW M Coupe
What are you referring to? The holes on the bottom arent really a big deal since they really just hold the cover plate for the flywheel on. The major interface between the engine and trans is on the top half..
imackz
Car: 280zx
Will it fit the vh41 & how much to post to Australia?
elwesso
2007 BMW M Coupe
no just for VH45.
SaintlyCharBoy
Car: 92 vert, KA died - awaiting VH41 + 5 speed MA5
elwesso wrote:What are you referring to? etc...
I think what he is referring to up top is the way the countersink/counterbore appears to be nonconcentric in reference to it's bore. This could be because of distortion due to the camera lens - I ran into this issue with a similar project, where the curve of the lens actually changes the reference angle to different locations different amounts. Also some of the countersinks appear a bit deep, which would pull the original bore out of round (and some cases breaks them into a neighboring hole).
When you started this project, I remember a cad drawing with a squarish profile. Did that ever go anywhere, or did you start again from scratch?
did you mill, plasma, or torch cut these, and is the outer profile based on an existing part, or simply cut off?
Is this a first piece?
elwesso
2007 BMW M Coupe
Yeah these first 6 pieces are sort of the test run, im sending 4 plates for testing to 3 seperate people...
We had a Dixon plate and my buddy who is a CNC guy made a model out of it.. The inner part and outer part were simply a tracing of the dixon plate. I need to make it a little bigger on the outer edge, but its pretty close.
All the bolt holes that hold engine and trans (on the top half) are all good.. The original bores of the drilled holes are a tiny bit out of round but the countersinks fit in there centered... I am not worried, if the dixon plate worked, this one will work.
Mazworx
How do you align the transmission up to your adapter plate? If there is no dowels to line it up, then the input shaft will be misaligned and cause clutch problems.
imackz
Car: 280zx
hi, does your adapter work on the vh41 & vh45 or just the vh45?
tmorgan4
Look 4 posts up.
imackz
Car: 280zx
Does anyone make an adapter plate for the vh41 to z32tt 5 speed box?
elwesso
2007 BMW M Coupe
Mazworx wrote:How do you align the transmission up to your adapter plate? If there is no dowels to line it up, then the input shaft will be misaligned and cause clutch problems.
I have dowels I just didnt put them in for the picture.
Return to “VH45DE / VK45DE / VK56DE Forum”
