Operation suspension... Complete! (NO 56k)
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Personally, i think the 350Z rays look cleaner on the Q, however no one has put them on the Q (the G35 rays)...... I dont think theyd look as good as the other rays... It wouldnt have bene much more for me to get a set with the tires already on it, but I just prefered the 350Z rays, plus they weigh less than their size!
Jberger
Wes,I need to replace the upper links and tension rods, can you give me an idea of how much your parts were?
thanks!
pito11213
Car: 2002 Chevrolet Suburban
I believe in upper links and rods you will spend about $250. Joes prices are pretty good in comparison to any dealer. And the Q has a lot of hard to get items.
elwesso
2007 BMW M Coupe
Jberger wrote:Wes,I need to replace the upper links and tension rods, can you give me an idea of how much your parts were?
thanks!
the Uppers are roughly $320 and the tension rods are about $170, thats for the ones I got...
Jberger
Great, that's what I needed. I've to have the adjustable upper links, to keep the alignment correct, so your post was perfect timing.
Did you order these direct or can Joe get them?
I probably should have PM'd you on this one, but I thought someone else might wanna know too!
elwesso
2007 BMW M Coupe
I like the way you think
Anywho, the links and the rods were for a 300ZX....
Think about this.. as long as the links dont get damged, al you have to do is replace the bearings and joints (in the uppers and tension rods, respectively)...
id say over 100k its cheaper than using OEM components...
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
Nice job Wes. I like those wheels better than the last ones. Looks sharp. As far as the suspension, it looks like you did a lot of nice things. You got the car low, but not too low. Looks just right with the right amount of wheel gap. Keep up the good work. Now you have to see what you do about those Nissan hubs and get Infiniti ones. I bet that's interchangeable with an Infiniti rim.
Modified by louiegz at 1:34 PM 8/11/2005
elwesso
2007 BMW M Coupe
louiegz wrote:Nice job Wes. I like those wheels better than the last ones. Looks sharp. As far as the suspension, it looks like you did a lot of nice things. You got the car low, but not too low. Looks just right with the right amount of wheel gap. Keep up the good work. Now you have to see what you do about those Nissan hubs and get Infiniti ones. I bet that's interchangeable with an Infiniti rim.
Yep thats next, ill be watching ebay... Theyre WAY too expensive from the factory, something like $20 each.
PoorManQ45
you want factory infiniti hubs? I'll trade you for your nissan hubs. plus $15
qship96
Car: 1996 Infiniti Q45
wes,looks good! did you address the springs not being seated correctly in the perches? this may affect alignment/ride height,so matbe best to do before spending for the align.
elwesso
2007 BMW M Coupe
qship96 wrote:wes,looks good! did you address the springs not being seated correctly in the perches? this may affect alignment/ride height,so matbe best to do before spending for the align.
Good plan... I havent addressed that yet, ill eventually rent a spring compressor and align them myself... Oh how my life would be different if I had unrestricted air tool useage!!
