Ever Victorious wrote:Not having changed the oil myself on my Versa, I don't know what sooner4x4 means by "strange looking" crush washer. Basically all the ones I've seen are designed the same, just for different sized bolt.
if it really bothers you, you can go to your Nissan dealer and buy a dozen. They're usually less than a buck each, and that will last you for a long time.
The crush washers used on the Hondas and Toyotas I have owned look like a regular washer. The Honda washer looked like a typical (aluminum?) washer. The Toyota washer is part black and part metallic looking. The Nissan washer on the other hand does not look like a washer at all. It has a strange cross section that crushes down to less than half of it's original thickness when the bolt is tightened. It is a copper color. It can be a real PITA to remove from the bolt sometimes to put a new one on. I am not sure how else to describe it. I have a few in the garage but don't know how to post pictures, and it would have to a very clear close up to capture the detailed (bizarre) shape.
When I saw the Versa washer for the first time, my first thoughts were, it is unlikely that the typical garage or oil change place (non-Nissan) would stock them or bother to use a new one. Again, I do not know how critical it is to always use a new crush washer. On my Toyotas I have used the same washer numerous times, but it just looks like a typical washer that doesn't appear to deform significantly when installed on a tighted bolt, like the Nissan washer does.
The worst thing that could happen from re-using a washer is the possibility of a leak or probably just a very slow drip at the drain plug. If owners aren't reporting leaks or drips then perhaps the need for using a new washer is unneccessary assuming washers are being re-used.
