breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Thu Dec 08, 2011 7:46 am
you can go a couple ways. on mine, I take off the three collector bolts, and yes there will be alot of pb blaster. but technically you could take of the manifold a rope it to the side enough to move out the motor, but to do this you will have to take of the bolt off the exhaust in front of the cat from its bracket.
I'd rather taker off 1 bolt and 2 nuts than like 8-10 bolts.
If you have access to a hoist it should be a fun weekend project that when finished should have you driving leak free for a while.
DO NOT FORGET...if you have time to replace the rear main seal, DO IT....its like a $10 seal that is a pain in the a** if it leaks. plus it take like 20secs to replace when the motor is out.
