The idea is to have an optimized oil setup (pump, filter, oil weight, oil temp, etc..) to maximize performance and turbo life, mainly on high horsepower , high dollar builds. so here are the key points we have thought up;
-optimum oil viscosity for the turbo.
- cooler oil temperatures.
-cleaner running turbos.
-no need to tap oil pans or filter plates/housing.
-more precision control over oil conditions.
-higher pressure when needed (high RPM, high HP).
-high capacity oil supply.
Now, with that said, I have never seen this done. I have seen similar ideas on remote or rear mount turbo setups but never have i seen a standalone oil supply for the turbocharger. The system would be composed of the following;
-electric oil pump. a few companies make these. (Mocal, Weldon, northern tool..)
-oil cooler. 8-16 row?
-high flow oil filter (Amsoil, Royal Purple, GReddy)
-high pressure lines.
-AN fittings
-custom remote oil reservoir
-accessories like oil pressure gauge, oil temp gauge, etc..
So, this seems like a good idea but i don't wanna roast a turbo doing this without some other opinions first. This is an idea of what the setup would work like.
So what are some ideas? opinions? Feel free to tell me I'm an idiot or that this has been done or whatever. I'm just looking for some feedback on this and hopefully some reassurance that this will work.
