Oil Pan Removal ? HELP ?
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
lostjohndean
Car: 1978 NISSAN 620
What's the easiest way to make clearance to remove the oil pan on a '78 620?
PEZi
removal of sway bar... suspension cross brace and then unhook one side of the steering
if its 4wd i don't really know... but i'm assuming its not
lostjohndean
Why do I need to remove the sway bar? Seems like the cross brace and center tie rod are the only things in the way . . . the manuals I have say you need to jack up the engine, but that seems unnecessary.
PEZi
well... you may not have to take out the sway bar but it did make mine easier
jacking up the engine is only needed if you don't want to remove the pieces mentioned above... i find removal easier than jacking it up though
lostjohndean
Got it without any problems... Just removed the cross-member. Don't know why you'd do it any other way. Thanks for the help.
Return to “Datsun 620”
