Oil leak
Novaw2145
Car: 1990 nissan 300zx na
Okay so i have a oil leak coming from right around the alternator and im puzzeld where its coimg from i replaced the exhaust value covers and could it be the pan gasket?
Reason: Moved to correct forum
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
If the oil is coming from above the alternator, no. If coming from below, then quite possible. A little more info would be great. Has the 120k been done? What's the mileage? Pictures are worth a thousand words, if you can get a decent snap.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Are you 100% sure its oil? Keep in mind that the PS high pressure hose crimp connection is a common place for a leak, located right next to the Alt.
Novaw2145
Its above im really sure bc it leaks on the top of the alternator and down on the motor mount i will post pics later today and no the power steering belt isnt on it and has no fulid in the resivor and my oil pressure runs good when i add oil but quickly goes to about 4 psi! But when added runs 30 to 40 psi at idle and i dont know it looks like the 120k has been done i would like to know what all is in the list of the 120k i know the timing belt has been changed and all valve covers car has 174k
Novaw2145
Oh yeah and i checked the pcv valves and they were kinda dirty but my uncle says that wouldnt case it what do you guys think
Ace2cool
If it's coming from above, it's coming from either the head or the cam seals. Or the VTC seals.
Novaw2145
Okay and how hard is that to fix depending if it was the head
Ace2cool
If it's the head, that's looking at probably 6 to 8 hours labor with an experienced mechanic.
Novaw2145
Whats a definite sign of head? Bc it still has power i bought the car for 1700$
Novaw2145
If it was the head wouldnt it have water in with the oil?
Ace2cool
No. There's many different ways a head gasket can fail, both internally (milky oil) and externally leaking. And you wouldn't necessarily lose power either.
The only way to tell is to pull the covers off and see where the oil is coming from.
Novaw2145
Thanks for the info so would my pvc valves make anything leak they were pretty carbonated when i pulled the plenum
Ace2cool
They would allow oil into the intake. Nothing external unless you have a broken or cracked hose, which is also common, but you'd see that leak ON the timing belt covers, not IN them.
Ace2cool
Unless they were completely blocked, in which case crankcase pressure could have built up and caused other problems, like blowing your dipstick out.
Novaw2145
Okay thanks i forgot to say it leaks under the manifold and has a little white smoke from the manifold
