Oil Leak! Please Help
Discuss topics related to the VG and VE series engines.
fairladyjzz
Car: 1991 Fairlady Z
could anyone tell me where the oil leak should be from?
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
more than likely it's the rear main seal on the engine. The seal itself isn't that expensive, but paying someone to get to it is. You have to pull the trans, clutch, flywheel off to get to the sucker. if its not that, then it might be the trans front shaft seal. either way the trans has to come out to tell. if the leak isn't bad, like a drop or 2 on the ground a day, you can probably let it go for a little while while you plan on what to do.
coolyun_98
Car: 1993 J30 11,7000kM
Try Auto-rx. Some people have had wonderful results.
Bronze MFP
None of the "stop leak" type products should be considered a permanent fix. if the engine is leaking, it means a seal or gasket needs to be replaced. Using coolant or oil stop leak products is just a good way to gum up an otherwise well-running engine. Fix it right.
coolyun_98
Auto-rx is NOT a stop leak product.
Return to “VG30 / VE30 Forum”
