Second, I noticed that my oil has been getting low slowly over time. The oil pan underneath the truck is fairly saturated around the seals, but it doesnt look wet if that makes sense. Higher up however I have noticed that there is leakage above the fuel filter, and that oil looks wet or more fresh. When under the truck looking up at the fuel filter there is a plug with wires going into and a rubber boot plugged into the engine. The leak seems to be originating from this area. Unplugged the wire and put back on making sure the boot was snug. Haynes manual not really clear in this area or troubleshooting a leak. 1984 four cylinder engine.
appreciate your help!
