oil filter relocation kit
dbody1
Car: cars/
Can any one tell me which brand (company name and part number) of a oil filter relocation kit you are using. Also will it have an opening for a oil pressure sending unit on it. Thanks for your help.
NeedCAforS13
Car: CA swapped S13 coupe
I'm running a B&M Oil cooler and relocation kit I got from Summit Online.
here's a link to the part: $109 is a kicka$s deal IMO. comes with everything needed to install (hoses, clamps, fittings, etc..):http://store.summitracing.com/...earch
and here's a pic of the engine bay (with the relocated filter on the passenger strut tower):
Sean
CA19DET
nice gatorade catch bottle
did you get that kit, and did ti have a thermostat?? there are fix-a-lite oil-sandwich-sapcer-adapters with built in thermos, also sick coolers with them built in..
you should run an oil thermostat with a cooler...
CA19DET
check that neet location for the S13... i really dont like how it looks but i am sure it would eb great for raod-racers/drifters
but anyway these ausies that made that bad 1200 Ute i posted amke these cool oi coolers with the built in thermo.. http://www.are.com.au/products/oilcoolers.htm
i also think on project nissan they sell the blitz and Greddy oil sandwich adapter paltes that have the built in thermo..
NeedCAforS13
mine doesn't have a thermostat, but being in Florida, it's never cold here (much like you in trinidad), so according to B&M its not an issue. Oil temps get hot enough, fast enough with a turbo motor, that it's not neccesary to run a thermostat. If you live up north and deal with freezing conditions, you might want to find one with a built in thermostat. They sell one on ebay for about $30 (sandwich fitting with thermostat and oil pressure sender hole).
dbody1
Car: cars/
I only want a relocation kit for the filter and be able to run my oil pressuresending unit from it also. No cooler at this time. Thanks
NeedCAforS13
holy crap Aaron, that skyline one is SICK.
fits alot better/cleaner than the s13 one.
NeedCAforS13
if you have some money to blow, the greddy kit is a good choice at $100:http://cgi.ebay.com/ebaymotors...wItem
or there's a knock off with no hoses for $60:http://cgi.ebay.com/ebaymotors...wItem
most imports use the same thread on the oil filter, so find an oil filter relocation kit for a nissan, toyota, mitsubishi, or whatever and it'll fit. If in doubt about a manufacturer, go buy a cheapo $3 oil filter from a parts store and test fit the threads on your CA.
Sean
float_6969
I bought a hayden, thermostatic oil cooler, and transmission cooler, off of eGhey for about $30 each. I had to get some extra hose, cuz I didn't have quite enough, but not bad IMHO. I don't have it hooked up yet, but the cooler is about 1/3 the size of my radiator, so it should do just fine.
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
ARE make real nice coolerswe run one in our cortina
all work there is exceptional
dbody1
Car: cars/
I guess what I really need to know is will a sr oil relocation kit work on a CAbecause I can get a greedy one at my local shop? Thanks.
float_6969
the cooler and lines might, but the actual adapter won't.
NeedCAforS13
I beg to differ Ryan. Nissan (and most imports for that matter) use the same thread pitch and size on the oil filters. The SR kit will most certainly fit your CA.
Sean
dbody1
Car: cars/
Thank you guys for the advice and help on the oil relocation kit. Sean, you where right the Greddy SR kit fit and is doing the job intend. thanks again to all
biosehnsucht
Are you sure the SR kit fits.
Remember the problems SR people have with oil filters.. not all SRs have the same thread and stuff.
IIRC most SRs use a different oil filter from the rest of the nissan engines.
CA19DET
if it didnt work he would have said so, it wouldnt have threaded up, and it did apparently
NeedCAforS13
biosehnsucht wrote:Are you sure the SR kit fits.
really? I'm pretty sure I tried all the Nissan oil filters when I worked at nissan to see if they would thread on my CA, and they did. The short little 350z filter, the tall fat KA filter, and there was a middle sized one too. IIRC the SR uses that tiny short one.
according to the SR FAQ section:S13 SR Oil Filter '91 Sentra SE-R
S14 SR Oil Filter '95 Sentra SE-R 15208-65F00
Sean
sdtouge
Car: 1990 240sx coupe
dang sean that is a amazing deal lol thanks for looling out.
relocation and cooler for 109$ lol:) nice find and thanks for sharing the wealth.
NeedCAforS13
no problem. It was actually a guy on clubs12 that sent me the link. He installed it on his CA18ET, so I knew it would fit my motor no problem
Sean
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i still dont get the need for a relocation kit
biosehnsucht
some SR owners have had engines let go cause their oil filter fell off
there are some SRs that have a different but almost the same thread and it eventually falls off..
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
cortina-mk1 wrote:ARE make real nice coolerswe run one in our cortina
I hafta agree too, one of our friends runs one on a 32 gtr, just like that maroon 33 gts-t, and it's pretty good. works a treat !
themadscientist
I was running twin mustang filters, PH8A, using a universal summit kit.
rexhunta
MY10 Forester X LE
themadscientist wrote:I was running twin mustang filters, PH8A, using a universal summit kit.
Oil is over rated and expensive.. i shaved 2 seconds off my quarter mile by just running water.
float_6969
NeedCAforS13 wrote:I beg to differ Ryan. Nissan (and most imports for that matter) use the same thread pitch and size on the oil filters. The SR kit will most certainly fit your CA.
Sean
I'm sorry, I was thinking of that Greddy unit that replaces the adapter that bolts to the block.
rico05
Car: 1992 RMS13 w/ CA18DET
That kit does look yummy, but rubber lines, and a tiny core makes me think that the $140 setup you can peice together with plates, braided steel lines, and a setrab cooler is the way to go.
