daniel240 »
https://forums.nicoclub.com/daniel240-u4418.html
Sun Nov 23, 2003 5:52 pm
well i got my feed line run and now i need to do the drain line.
1st ? will rubber hose be ok to use if i wrap it in heat tape?
2nd? if i use a 90 deg. elbow to run the hose to, should i put it in the oil pan or the engine block? i saw the SCC mag article they drilled a hole in the block and tapped it. however, i hear most people run it to the pan. is the pan too thin to tap threads into? and if so, is it alum. or steel, because i have a welder i could use if its steel. thanks
-dan
