sooner4x4 »
https://forums.nicoclub.com/sooner4x4-u71453.html
Sat Mar 15, 2008 3:30 pm
Can't help you with a picture, but if you have changed oil on other vehicles, it should be pretty obvious on the Versa.
The oil filter is a PITA to get to in my opinion. It is in an ackward location. I was unable to get it off the first time. Versa Madness is right about the factory oil filter being on very tight.
The funky drain plug crush washer can be a little tricky to remove from the bolt.
