GSlone12 wrote: ↑Wed Jan 08, 2025 12:54 pm
I have a 2023 Rogue Platinum with the 1.5 Turbo. I've been changing my own oil and using a WIX oil filter. And while at the dealer the other day a service guy told me changing my own oil and not using the Nissan OEM filter can and will give Nissan a good reason not to honor any warranty issues for engine failure. What say you?
Also, I have always used an aftermarket fuel additive in my vehicles periodically for a very long time as a way to hopefully prevent injector issues, but I noticed in the Rogue owner's manual it says don't. What say you on that topic as well?
Aftermarket fuel additives
NISSAN does not recommend the use of
any aftermarket fuel additives (for example,
fuel injector cleaner, octane booster,
intake valve deposit removers, etc.) which
are sold commercially. Many of these
additives intended for gum, varnish or
deposit removal may contain active solvent
or similar ingredients that can be
harmful to the fuel system and engine.
