All that just to get to the headlights! How about just changing a bulb in the housing? Do you think I would also need to do the same?marksport wrote:...To get to the headlights, you have to remove some of the lower cover bolts, remove both the fenders and then the bumper...
Unfortuately, yes. I didn't see any other way around that as there is always something in the way. Is one of your headlight bulbs burnt out? Overall, it's not a difficult job, takes about 45mins-1hour. Probably designed this way so that only the dealer could sell/serice the headlights and bulbs. Download the FSM, and print out those parts if you plan to change your bulbs.DuDro wrote: All that just to get to the headlights! How about just changing a bulb in the housing? Do you think I would also need to do the same?
No burnt bulbs...I wanted to replace the factory high beams with whiter, brighter bulbs.marksport wrote: ...Is one of your headlight bulbs burnt out? Overall, it's not a difficult job, takes about 45mins-1hour...
The shop did it. Not sure what exactly they did but they told me they woud have to make one because they were unable to find one for the car. I figure they took the mesurements and cut another roof spoiler and added fiberglass to it so it would fit flush with the rear windshield.Falkdesigns wrote:
Widebody, how did you make that roof spoiler?
1. No fitment problems whatsoever.sterling_michaels wrote:Marksport, I like the look of your Q with the FX rims. I have a couple questions?
1. Do you have any fitment issues: rubbing on bumps, full locked turns, etc?
2. How has the ride changed, a lot firmer, does it ride like a rock, etc?
3. Are the tire pressure sensors the same types that are on your 18inch wheels? How much did the second set of sensors cost?
4. Any downsides to using the fx wheels? Braking issues, extra weight, etc?
Thanks a lot for your help.
The 06 Q-Sport wheels have 10 mm less positive offset than the 06 M-Sport wheels. So the 19" M rims will sink between 3/8 to 7/16 of an inch further in on the F50 than the 19" Q-spec wheels.SonzofGod wrote:I would like to put on the 19" 2006 Q45 rims (also same as M45 sport I think) or maybe the FX45 20"....
THe wheels on the Q sit further out rather than sinking in than the m45.TgduMg wrote:
Though .4 of an inch doesn't seem like much a good eye will catch it.
M-Sport 19" wheels: 19x8.5 +50mmQ-Sport 19" wheels: 19X8.5 +40mmFX35/45 20" wheels: 20x8 +40mm
Danisiti 1
Yes, that is correct if they are the +40mm wheels specified for the F50. But if the +50mm 06 M-Sport wheels are used on the F50, they will sit further away from the wheel openings than the Q-Sport wheels.2005Q45inCali wrote:THe wheels on the Q sit further out rather than sinking in than the m45.
