dangeris »
https://forums.nicoclub.com/dangeris-u76570.html
Fri Sep 12, 2008 11:29 pm
Brandon, I've shot you two emails but you haven't replied. I know that you said you were super busy and that you wouldn't have time to reply but I really need to know if you could do this mod for me if I decide to go with dual projectors setup and before all of the spots are gone for this buy.
Basically, what I'm going for is instead of angel eyes. i would like to have the flexible LED strip form Oznium installed underneath the OEM shroud. This way it's protected by the elements. Basically I want it to look like this but the LED strip is INSIDE the headlight. I'm not sure if there is enough room for the strip or not but Oznium has the height specifications for the strip on their website. I believe it's less than 3/8"on an inch thick. Since you have the lights apart, you would know if it would fit or not or if you have to cut the OEM shroud to accommodate for the thickness of the strip.
Also, another question would be the Bi-Xenon setup. If I opt for that, when I put on the highbeams, will both the Bi-Xenon and OEM high beam kick on
Let me know brandon because I'm really really interested in doing this mod for my baby!
