oem ca18 oil cooler
sdtouge
Car: 1990 240sx coupe
heyyesterday i was pulling stock of my block starting the tear down and the oil filter bracket thing chiped a little bit, so i figure might as well when replacing get the oem oil cooler.
if anyone has an extra one lying around let me know becuase ill buy it, or if anyone knows what that piece is called then ill just order one from online or soemthing pulsar style.
thanksmatt
slownslurious
why not just go with an aftermarket one? Go to the junkyard and pull one off an RX7, they had decent sized ones, and they will work better than the ca's stock one anyway.
sdtouge
im just talking about this little piece that is what your oil filter mounts too. coolant flows in it and cools it a little bit.
i dont really want to do wiring and tapping etc for a external oil cooler, but i figure might as well try this since it should be pretty easy to hook up and i ned a new one ayways.
slownslurious
what do the motors that don't have an oil cooler have where the coolant lines are on the motors that do?
sdtouge
^ i didnt understand thatbut i think you said what do cars that have oil cooler that are air cooled do?they run lines to a oil cooler usually in front of the raditor area.
slownslurious
no my car has oil cooler and it has a bung on the block back by the heater hose where the coolant comes out to go into the cooler. What do the cars that didn't come with the oil cooler have ?? I'm just thinking that if you buy the stock oil cooler the stock coolant lines might not be there.
biosehnsucht
Correct. There are different fittings for the oil cooler's connection to the coolant system.
It will connect to the lower rad pipe coming out of the block and to the fitting coming from the block to the heater core at the back.
My engine didn't have the oil cooler but I got one from someone in the UK on SXOC and got various T fittings to duplicate the function, if not the form, of the original oil cooler equipped motors.
AFAIK JDM motors only had oil coolers if they were automatic, but all EDM cars had them.
slownslurious
mine had one, next time I have the kickpanel off I'm going to check the ECU to figure that out.
flohtingPoint
Car: 2004 Z16 Corvette Z06
biosehnsucht wrote:AFAIK JDM motors only had oil coolers if they were automatic, but all EDM cars had them.
Whoa, I wish!!! I have yet to see an EDM S13 w/an oil coooler unless you mean a diff oil cooler. No motor oil coolers though, and I've done quite a bit of dumpster diving here in the junkyards of Germany.
zero_gripS13
Car: soon to be 95 s14 hopefully
does anyone know a company that makes the sandwhich plate to go between the oil filter, that hase the too line outlit for and external oil cooler, or do u guys know some trick to hgooking up and external oilcooler to the ca?
themadscientist
trust (Greddy)
slownslurious
spl parts has one too...greddy one doesn't have very nicely sized outlets for an oil cooler
of course summit racing's is cheaper and the , and the summit racing one is purpose designed for that... thats probably what I'll use, I'm planning on upgrading to an air cooler soon.
themadscientist
jamik_69
slownslurious
the link tms posted was for the greddy oil filter relocation kit, not their sandwich adapter. I've owned their sandwich adaptor and the lines are not large enough for a decent oil cooler application... so don't be confused.
biosehnsucht
maybe its UK only then because I got mine from someone in the UK, and from SXOC forums it looks like alot of people have them..
are you sure they're not on the motors in your area? It was available on both manual and automatic, and AFAIK it was standard equipment; it won't be a large radiator style cooler like the Z but a small gizmo on the oil filter mount that passes coolant through it to cool the oil.
flohtingPoint
biosehnsucht wrote:maybe its UK only then because I got mine from someone in the UK, and from SXOC forums it looks like alot of people have them..
Oh, you can get oil coolers, they just dont come stock. I've seen 200sx's from here in Germany and in the UK, both of which did not have stock oil coolers. The only really "special" things we get is no speed limiter and a 4 port head. Oh yea, we also get a craptastic 3.91 diff too, whoopie =/
biosehnsucht
They're OEM peices. If they're part of some option package or not, I don't know, but they are OEM.
I can supply screenshots from the European parts catalog to prove it. If you have access to it yourself, look at section 213.
flohtingPoint
Seen the link off your web page, but I'm telling you, I've never seen such a thing exist. If this was around, I'd have a stock pile of them, sorta like my mini pile of 4 port CA heads and diff coolers.
The rest of your manual looks like a JDM motor, not a euro motor. In fact, alot of the placements for items in this catalogue is not euro at all.
biosehnsucht
heheh which part of the site. I have one part that is a work in progress that is JDM stuff. the wiring schematic is EDM tho. If I can scan my JDM FSM w/o damaging it and get good scans I'll scan stuff from it too..
but yes section 213 of EDM stuff has it too:
Jezz_s13
Car: Sil80 Track Car
All UK S13 CA18DET's come with oil coolers, it wasn't an option.
