marcyprojects wrote:Recently installed megan lowering springs on the Z. Install went basically without a hitch, had to do a little man handling to get em in but not bad. Drives fine for the most part but I have an odd issue on hard turns. I accelerate through a corner at around 35-40 mph and im getting what feels like wheels skipping in the front if that makes sense. Like the front wheels are loosing traction. Ive gone back and checked all my bolts, bushings, even had my alignment re checked and still no change. Tires arent rubbing, alignment checks out good. Am I to think that this is just how it is now that im lowered? Never had this issue with the 3 other lowered cars ive owned. The drop on the Z with the megans is about 1.75 so its noticeable but not slammed. Anyone seen this?
Well Ill tell you what I did do, which might seem bad but made sense at the time. When I tore down the suspension on all 4 corners I found 2 blown struts which I replaced with "known good" struts from a friend. The 2 blown ones were completely gone, fell right to the bottom when I separated it from the spring. Stock springs must have compensated somehow because I had zero issues at stock height. So I basically have 4 solid but used Tokicos all around. Just me using what parts I already had access to instead of spending money on more parts. As far as the springs, I went with the megans as they have the most agressive drop. Having driven on them now, the only thing I dont like is the softness of the ride sometimes. Drives fine in a straight line and light turns moderate acceleration but if I try to gas it around an corner or a u turn, the front end is banging like the wheels are skipping across the ground.Ace2cool wrote:32/34 is close enough for government work.
Did you replace shocks? This is an old car, and the shocks probably haven't been replaced. What brand springs did you use?
ya ive heard the general consensus on that. Just didnt make sense not to use them since they were right there. They had plenty of recoil when I checked them out. Got em from a parts 90k parts car owned by a guy locally who runs an auto recycling business in my area. Basically gave em to me and I held on to the set just in case. Car was a 96 2+2Ace2cool wrote:Huh. I'd definitely jack the front up and see if anything was loose or anything like that. I don't know that I'd ever do the wrench work to put used struts on, though, lol.
NolimitZ32 wrote:I have 2 sets of good struts and springs (one is a set of tociko blues with less than 6k miles on them) <shameless plug
Indeed. I had the car aligned at my local nissan dealership last week. Theres a guy there that does specialty alignment for everyone here in town, very highly reccomended. It is definately better than it was when I brought it to him. According to him the front end lined up basically dead on. Is there anything that I can add to the setup to give more caster adjustment, maybe adjustable tension rods?NolimitZ32 wrote:Damnit, I didn't check the thread, sorry. As for what you are referring to is called caster and happens when your strut assembly is not properly aligned, IF there is no underlying issue like bent suspension parts this is something that should be able to be fixed by a good alignment shop.
marcyprojects wrote:Indeed. I had the car aligned at my local nissan dealership last week. Theres a guy there that does specialty alignment for everyone here in town, very highly reccomended. It is definately better than it was when I brought it to him. According to him the front end lined up basically dead on. Is there anything that I can add to the setup to give more caster adjustment, maybe adjustable tension rods?NolimitZ32 wrote:Damnit, I didn't check the thread, sorry. As for what you are referring to is called caster and happens when your strut assembly is not properly aligned, IF there is no underlying issue like bent suspension parts this is something that should be able to be fixed by a good alignment shop.
NolimitZ32 wrote:The Z32 is nto exactly your grandpa's cadillac and will never have the ride of a cloud, I would agree that its a rough car to drive in comparison to many others however you gotta realize that much like the ride of M power and AMG cars (which owners complain about constantly) the Z32 was designed as a Japanese bahn-burner so to speak, its made for long fast drives down wide open roads (like the autobahn). So generally any city driving won't be as comfortable and it only becomes more apparent with age, your age and that of the car.
No worries. Your comments are always appreciated man. Everything is still going great as of now. Things really seemed to fall into place now that the springs and new struts have settled. Im still not super satisfied with the ride height, still would like to shave another inch off but as we have proven its just not possible without coilovers. Sadly, this whole learning experience only fell about $100 short of just buying coilovers but lesson learned. I may still opt for them later but for now im focusing more on my engine performance and trying to squeeze as many extra horses out of this NA as possible.DCaff300ZX wrote:Sorry I missed this until now...but seems you are now on track.
The tension rods are a must with any lowering, as really are adjustable FUCAs and RUCAs to avoid similar issues where alignments and tolerances can't be matched such as camber and the caster issue you now face. When/if you use Powertrix you most likely will speak with the owner Charles, who is a great guy and will if asked answer ANY suspension question you have and guide you through the process. Powertrix is a quality product with service second to NOBODY, highly recommended.
Good Luck with your repairs, and as you have found don't skimp on the necessary items.
Powertrix has their group buy pricing available still for some extra gb units and parts, so now is also a good time to look into coilovers which is the more "proper" way to lower the Z32 and/or upgrade the suspension over shock/spring combos with no other upgrades and adjustments possible.
