obd1 KA24DE swap wiring with consult
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
I wanted to start a thread to address the wiring harness for the ka24de ecu, more specifically how to wire it into an 89-90 240sx without loosing the ability to use the CONSULT cable.
First let me start by saying that the ecu harness for the ka24de is different between the 5speed and automatic. when i began my swap i never herd this but i guess it makes sense. the auto harness has an additional plug just up from the ecu, i would have to imagine it connects to the transmission controller and sense no one has ever mentioned it before (so long as you dont have an automatic) it could probably go untouched and disconnected with no ill effects. I used the 5speed harness.
When wiring your dohc the brown connector on the ecu harness needs to be rewired to connect to the white body plug. most ppl simply cut off the sohc harness connector and solder it on to the dohc harness, i suggest repining.you can open the connector pin holder with a small flathead screwdriver (one holder on either side) and slip the pin out after inserting a saftey pin into the face of the connector from the center and sliding along the underside of the pin untill you unlock the seccond catch. after repining it looks like this.
The wires go into the sohc connector in the same locations thay came out of it so that the end result is a dohc harness with a sohc plug.ie black - black, red - red, and so on. what those wires do are as follows.
Black = Ground
Red = Check Engine Light
Orange = Start Signal
Yellow/Green = Speedo
Blue/Black = Water Temp
Yellow/Red = Tach
Green/Yellow = Rear Window Defrost - not used on sohc models
Blue/Green = Thermo Control Amplifier - ok so i dont really know what this is but its in both models, my guess it idles up the motor when you turn the ac on.
the next little bit here is my favorite part. i personally have every intention on getting a CONSULT cable and was quite disappointed at the idea of loosing my CONSULT port. so here is how to keep it.
first you should source a CONSULT connector from a donor 240 or other consult equipped nissan (ie junkyard) thay look like this.
wiring it up is fairly straight forward, again color match, this time i didn't repin the connector i soldered mine because i wanted it to have enough length to be accessible. (the cable is easily accessed through the glove box, great location!)
Green = RX
Green/Black = TX
Green/White = Clk
the next two take a little explaining
Black = Ground - i spliced and soldered mine into the other ground, both of these grounds run back out to the engine bay and ground out on the head along with any other ecu ground (get a ground kit!)
Green/Blue = 12+ key to on or start - this line will supply voltage to any tester that dosent supply its own power source. its also possible that some CONSULT cables may use it. i ran this line back across my dash and into the back of the original sohc diagnostic connector. it is located in the kick panel by the drivers side fuse box. the wire you want should be Black/Red.when your done it should look like this.
well i hope this helps someone.
Modified by moso at 9:47 PM 8/22/2009
Modified by moso at 8:07 PM 8/23/2009
jlwade
Car: 1990 240sx
I thank you a lot. I am putting a 1992 engine into a 1989 body. Can't seem to find anyone that knows exactly how to match everything up. This will help some. thanks again
motoman399
Car: 98' wrecked (RHD coming soon) 240
sweet maybe we can finally get my friends car running!!!
jmborek
Car: 89 s13 coupe
Just wondering if stock 89 tach will read the signal or if a 93 tach is needed?
jlwade
Car: 1990 240sx
They say no but I am going to be trying to do just that in a week. Putting a 1993 engine in a 89 model. I know wiring harness is a little different.
moso
90 240sx ka24de RIP
the 89-90 tach will NOT work with the ka24de. i swapped out the whole cluster but you can swap out just the tach, i believe there is a writeup somewhere on this site.
jmborek
Car: 89 s13 coupe
thanks for the write-up moso, im looking forward to the swap and i might just swap the whole cluster since i have a complete hatch donor for the swap
vancouverbc
Car: 1991 240sx
You are putting a dohc motor in and keeping the sohc harness?
moso
90 240sx ka24de RIP
no were wiring a DOHC harness to work in a SOHC chassis.
