OBD II port
tokata3620
Car: Infiniti G35
Hi everyone. I drive 2005 Infiniti G35. Couple months ago i tried to pass state inspection but the OBD II port on my car did not communicate with the computer in the shop, so i was not able to pass the inspection. Does anybody now what the problem is?
Thank you. Tod
telcoman
tokata3620 wrote:Hi everyone. I drive 2005 Infiniti G35. Couple months ago i tried to pass state inspection but the OBD II port on my car did not communicate with the computer in the shop, so i was not able to pass the inspection. Does anybody now what the problem is?
Thank you. Tod
Welcome to NICO
I use this to communicate with my G
I wonder if perhaps the inspection station did not have it properly inserted?
Go back again and ask for a supervisor
Telcoman
tokata3620
Car: Infiniti G35
I don't think there is something wrong with the inspection station because on the next day i tried with another shop and i had the same problem.
telcoman
I wonder if any wiring changes were made?
Not sure if there is a fuze somewhere.
You may end up having to take it to a dealer
tokata3620
Car: Infiniti G35
Ok.Thanks.
joe603
Car: 2014 Durango R/T
I'd try a different shop...I've never had a problem with either of my G's. We have emission testing in my county.
tokata3620
Car: Infiniti G35
I tried with another shop and i had the same problem.
joe603
Issue with the car then...maybe a pin on the OBDII port is broken?
tokata3620
Car: Infiniti G35
I will check the port. Thank you.
telcoman
tokata3620 wrote:I will check the port. Thank you.
The cable that comes with the Actron has a db15 male connector that plugs into the top of the Actron.
If you have a breakout box plug the db15 into it with the other end connected into the OBDII port.
That cable has 12v and ground among onther connections. I' assume one or more connection has an open
Telcoman
tokata3620
Car: Infiniti G35
Ok Thanks. I will try that.
