OBD-II diagnostic connector
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
powergrip
Car: 2008 Nissan Versa SL
Does the Versa have a OBD-II diagnostic connector and if so where is it located? I want to install a trip computer into my car. Thanks!
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
Yes - pretty much above the gas pedal at the bottom of the dash. (Page GI-38 in the Service Manual available on this site.)
WORKS89
Car: EVO VIII GSR, 07' Versa 6spd, AND 92' Z32
powergrip wrote:Does the Versa have a OBD-II diagnostic connector and if so where is it located? I want to install a trip computer into my car. Thanks!
Whats a trip computer
J. Reid
Car: 2008 Versa S
He's probably referring to something along the lines of a Scanguage 2 (which I bought for my V as well)
masa3
Do you think the scan gauge is accurate and worth it. I am planning to get one too. Does it have any affect on the cars battery or mileage if I install one. Any suggestions please
leonj
I have a SG2. Is it accurate? Yes. Just follow the calibration procedure and the initial set up in the owner's manual. Mine has been within 1% (vs a manual math calculation Mileage divided by gallons). Is it worth it to save gas? Only if you use to temper your foot pedal. You can use it to measure instant MPG. Does it affect your gas mileage or improve it? No by itself. It's just a monitoring device, only your foot behavior will save gas. What I found it more useful for is to calculate distance to empty or gallon of gas left in addition to measuring mpg.
bigdog
Car: 2007 Nissan Versa S
2007 Nissan Xterra
1982 Dodge truck
it does help you save gas because you end up wathching your mpg trying to make it better & better,lol. it does work though w/gas milage.
Return to “Versa Technical Discussions”
