OBD-II Codes
Belewis1980
Car: 2001 Nissan Max
I am getting a OBD-II code P1447 and I have trouble starting the car when I put gas into the car.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Welcome to NICO! Glad you've found us.
Here's what the code means:
P1447 - EVAP Emission Control System Purge Flow Monitoring
I'm not exactly sure what this is referring to, though...the PCV maybe? Hopefully someone better at diagnostics will pop in soon. Sorry I can't be of more help.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Also found here:
5th Gen SES/CEL Codes
generation2000
i got the exact same problem p1447 and p1400
i know what the p1400 is but cant figure the other HELP
Beancooker
generation2000 wrote:i got the exact same problem p1447 and p1400
LOOK HERE: http://autorepair.about.com/cs...4.htm
maxibronxbomber
Car: 1997 Nissan Maxima 3.0
Hi Guys, new here but origianlly with NYCMaxima.org...if anyone is familiar..Good to be here and meet you all...
I see you have the same problem code P1447 and am not able to find a replacement part to repair this myself...
My code shows tells me it'sfor the EVAP purge flow monitor fault...I own a 97 Maxima 3.0..
Does anyone know where I can purchase this part..TIA
tigersharkdude
Car: 1999 Nissan Maxima
P1447 = 0111
another forum wrote:0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
During purge, the Evap Canister is connected to intake manifold via the Evap Canister Purge Valve but the Pressure Sensor is not seeing enough pressure drop, resulting in the trouble code. Check the Evap Canister and tubes/connectors for leak/crack/loose fitting. Mark each tubing before disconnecting as wrong connections will make it more complicated. If Evap Canister and connections are are good, you may have to replace the Evap Canister Purge Control Solenoid Valve.
